Results 1 to 15 of 15
Thread: Peavey transistor cross reference
    Noodle of Reality Steve Conner's Avatar
    Glasgow, Scotland
    7,251
    Received: 13/0
    23
    Here is the Peavey transistor cross reference guide. Peavey house numbered transistors are mostly ordinary Motorola (On Semi) parts, and this document shows which are which.
    Enzo's top tip: The MJ15024 and MJ15025 from On Semi will replace most blown TO-3 outputs.
    Attached Thumbnails Attached Thumbnails PV Semi Cross Ref 2009.pdf
    Jul 2010
    Duluth MN USA
    101
    10
    Peavey schematics
    What's the best way to get Peavey schematics?
    Glasgow, Scotland
    7,251
    Received: 13/0
    23
    I believe you can call Peavey and ask for them. As far as I know, they give them out freely and also sell spare parts direct.
    (You don't actually have to cross-reference those transistors, you can order replacements from Peavey by the part number that's printed on them.)
    Jul 2010
    Duluth MN USA
    101
    10
    I just emailed their parts department. Seeing as how it's Saturday I'll wait till Monday to call. Thnx
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    31,787
    Received: 1,660/7
    54
    customerservice@peavey.com good for schematics and other information
    Parts@peavey.com for information and questions only about parts, no orders taken by email for parts. They will take schematic orders by email. Customer service is usually faster.
    Phone call to parts at Peavey - ordering parts.
    Of course all the departments take phone calls if you prefer over email.
    Old Timer oc disorder's Avatar
    Jul 2006
    Land Down Under
    1,268
    Received: 4/0
    Given: 1/0
    15
    Peavey replacement board for TL604
    This is the sheet Peavey send with the TL604 adapter board plus some
    pics of the real McCoy..
    TL-604 SN-99661 SPECIAL HANDLING 70400604 CMOS
    Enzo Quote
    70400604 is just PVs part number for the TL604. SN99661 is also just a house number for the TL604. They are the same.
    Texas Instrument quit making the TL604 a long time ago, but PV had used tons of them in their designs over the years. When stocks finally ran out, PV had to do something. This is what I absolutely love about PV. Rather than tell us that the part was no longer available, they made a work around. They made a little board with a couple small components on it, and 8 legs sticking down. This subassembly fits where the TL604 used to be. They sell it at reasonable cost, and those 20 year old amps will now be running anouther 20 years.
    Thought it may be useful
    Attached Files Attached Files
    Junior Member
    Jul 2012
    10
    0
    Thats a great table, thanks a lot.
    Jul 2006
    Land Down Under
    1,268
    Received: 4/0
    Given: 1/0
    15
    Peavey-TL-604-Adapter.pdf
    Quote Originally Posted by oc disorder View Post
    Enzo Quote
    Dec 2008
    Wernersville, PA
    12,861
    Received: 479/3
    Given: 250/0
    26
    And as a bonus, you have available 3 unused switches.
    Jul 2006
    Land Down Under
    1,268
    Received: 4/0
    Given: 1/0
    15
    Some Peavey Footswitch Info
    Well here is some older footswitch info from Peavey perhaps a better bonus JPB (3 years later)?
    When I found it couldn't resist posting here. And some more from the helpful Peavey forum thanks to
    Roger Crimm at Peavey Customer Service
    Pin configurations of some DIN connectors on Peaveys.
    On the 7 pin connector (looking from the solder side on the connector) the pins are numbered starting at top right (one o'clock position).
    5150 II/6505 Plus
    Pin 1. +17VDC supply to pedal
    Pin 2. not used
    Pin 3 Ground this pin to detect the footswitch.
    Pin 4 Ground
    Pin 5 Activates the crunch function of the clean channel when grounded.
    Pin 6 Turns the EFX loop on when grounded
    Pin 7 Selects between the clean and lead channels( Lead when grounded).
    Triple XXX/JSX/3120/Triple XXX II
    Pin 2. not used
    Pin 3. Ground this pin to detect footswitch
    Pin 4. Ground/Common
    Pin 5. Clean/Bypass
    Pin 6. Ultra/Crunch
    Pin 7. Effects
    Ultra Plus/Ultra 60/Ultra 120
    Pin 1. Bypass/Clean LED on footswitch
    Pin 2. Reverb Led
    Pin 3. Ultra/Crunch LED on footswitch
    Pin 5. Clean/Bypass
    Pin 6. Reverb
    Pin 7. Ultra/Crunch
    XXL
    Pin 1. Bypass/Clean
    Pin 2. Reverb Led
    Pin 3. Ground this pin to detect the footswitch
    Pin 5. Leds (not used)
    Pin 6. Effects Loop
    Pin 7. Ultra/Crunch
    Senior Member vintagekiki's Avatar
    Jul 2006
    1,454
    Received: 216/1
    Given: 176/0
    16
  12. #12
    Member patlaw's Avatar
    Jun 2012
    216
    Received: 54/0
    Given: 21/0
    8
    This schematic is behind a pay wall. Can it be posted elsewhere by someone who has access?
  13. #13
    31,787
    Received: 1,660/7
    54
    WHAT schematic is behind a paywall? Any Peavey schematic can be had for free by contacting customer service at Peavey. That includes the semiconductor cross reference.
  14. #14
    Dec 2008
    Wernersville, PA
    12,861
    Received: 479/3
    Given: 250/0
    26
    Here is the cross reference document: Click image for larger version.
Name:	PV Semi Cross Ref 2009.pdf
    1 Not allowed! Not allowed!
  15. #15
    Jul 2006
    1,454
    Received: 216/1
    Given: 176/0
    16
    Quote Originally Posted by patlaw View Post
    Download the schematics is free, but portal requires prior registration.
    Registration is free.
  1. Peavey cs1000x transistor equivalents
    By retgaz in forum Music Electronics
    Last Post: 12-18-2016, 06:39 PM
  2. Late 90's Peavey Transtube Supreme repair (power transistor questions)...
    By RJBAudio in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-16-2011, 12:21 AM
  3. Cross referencing-finding parts
    By Valvehead in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-01-2009, 10:44 PM
  4. Peavey KB100 - overheating power transistor
    By dissonance in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-04-2009, 08:02 PM
  5. Peavey output transistor substitution?
    By Neal in forum Music Electronics
    Last Post: 11-22-2006, 12:54 AM
