Behringer mx3242x power issue. Please help if you can!!
  • Behringer mx3242x power issue. Please help if you can!!
    Hello,
    I have two of the Mx3242x boards with power supplies. Is what I need is a place to buy a new 7 pin female input jack for the power cord that attaches to the mixer. I have spoken to Behringer and they said I would need to purchase a new power supply, but I already have two that work fine, just the jacks are worn out.
    Any clues??
    Thank you,
    Jeff
    Not too sure of the pin arrangement.
    Google "7 pin DIN connector plug".
    Link:Neutrik DIN Connectors Male 7-Pin Cable NYS323
      It's an XLR, not a DIN, isn't it?
      Mouser has a selection of them, search XLR in the audio connectors, then female, cable mount, 7 circuit
      All the stock numbers start 568-NC7...
      The options include straight or right angle, black or shiny, plain contacts or silver or gold plated.
        Thank you!
        You have pointed me in the right direction. I know need to figure out if one of these will be an exact match with the pin spacing or if I need to replace both male and female ends.
        Thank you and if you have any more advice I am all ears and eyes!!
        Jeff
          We have both the cable female and chassis male in stock if you need it.
          John R. Frondelli
          "Mediocre is the new 'Good' "
            Hey John, Thanks for the reply. I looked over your parts list and could not find the connector for the mx3242x listed. If you could send me the part number I will call an order one!! I have two of these units that need to be fixed. I already bought one set of ends, but I need more parts for the other!
            Send me the info and I will gladly order!
            Jeff
              You are a life and money saver! Thank you for the help! I got the parts from Mouser very quickly and everything is back together and functioning like it should! THANK YOU!!!!!!
