In a grid leak biased preamp (this is 12ax7), what is the purpose of a small bypass cap across the grid leak resistor? This amp uses a 6.8M grid leak resistor but is bypassed with a 500 pf cap. The other channel is a more typical cathode bias setup, although it uses a 470K resistor to ground rather than 1M Fender/MArshall value on the input, but interestingly enough, that 470K resistor is also bypassed w/ a 500 pf cap. Is this some way to cut off high frequency oscillation potential, or some kind of RF blocking? I had always read that you "could not" bypass a grid leak resistor. ????
Grid leak/contact bias preamp
This 500pf cap is in addition to the gid leak cap between tip & grid leak resistor?
Out of interest, why wouldn't you bypass the grid resistor?
It would shunt a lot of signal & highs to ground, maybe a mechanism to stop the grid leak input from choking under big signals (one of their big failings)?
I get you. Indeed, some harp players have used a shunt resistor accross crystal mic elements to brown out bright mics, values could be anywhere <1000pf, similarly a cap this size might bypass a plate resistor at the input stage for the same reason. How does it sound? What's the amp?
Well, why not take 500pf and 6.8M and calculate what freq that represents. I'd be thinking that super high impedance is just begging to be a radio receiver, and the cap is there to bleed off any RF that comes knocking.Education is what you're left with after you have forgotten what you have learned.
yeah... That's a little below RF, if that's the actual frequency. I don't know the formula but isn't it relevant to that caps pass frequency that the load resistor is in parallel to the plate impedance???"Take two placebos, works twice as well." Enzo
I think that the a low pass filter turnover frequency would depend on the source impedance, which would effectively be in parallel with the 6M8 (assuming I've understood the layout correctly). And the 500pF would also be in parallel with cable capacitence from the lead to the instrument, which would likely be another 500pF to 1nF.
So at a rough guess, the roll off would kick in around 2kHz.My band:- http://www.youtube.com/user/RedwingBand
LAyout is (normal input) guitar cable--->unswitched jack--->47K--->.05 cap--->6.8M/500pf to ground--->12ax7 grid
Treble input is the same, except switched jack and instead of the 47K, there is a .005 cap prior to the big .05 cap.
I think the easiest thing to do is just lift one side of it and see how it sounds!
It's an old Supro, 1957 serial but no model number. I have a few from the 57/58 period, these have the grid leak front end on channel one but I've nto seen two the same. Have never been able to find schematics - I tried drawing one out (a 1690t) a while back but it's such a rat's nest in there it's easy to miss things.
Originally posted by pdf64 View PostI think that the a low pass filter turnover frequency would depend on the source impedance, which would effectively be in parallel with the 6M8 (assuming I've understood the layout correctly). And the 500pF would also be in parallel with cable capacitence from the lead to the instrument, which would likely be another 500pF to 1nF.
Remember a guitar cable has capacitance due to the shield, and some shielded cable has capacitance of more than 100pF per meter, or every 3feet. So a typical guitar cable has more than the mentioned 500pF, and we don't seem to care about that.
Perhaps such a cap at the input is what gives that vintage rounded jazz tone?
Originally posted by redelephant View PostRemember a guitar cable has capacitance due to the shield, and some shielded cable has capacitance of more than 100pF per meter, or every 3feet. So a typical guitar cable has more than the mentioned 500pF, and we don't seem to care about that.
Originally posted by redelephant View PostPerhaps such a cap at the input is what gives that vintage rounded jazz tone?"Take two placebos, works twice as well." Enzo
