What is the problem? I've worked on a few of the SS Fender amps and some were just simple soldering problems and one was just a bad MOV at the power input.
I don't get any sound when playing through the clear channel (main inputs). The green clear channel light does not go on (but the power light on the overdrive channel goes on). The only way I can use it is by plugging my guitar into the effects loop input. I get some sound that way but not much and none of the controls on the front of the amp will do anything. I opened up the amp and checked the fuse and it was OK.
Thanks for the help. I tried plugging my guitar into a smaller amp and then ran a patch cord from that amp's headphone jack into the effects loop jacks (didn't really matter which one) of the M80 and got plenty of sound. I got no sound when running the patch cord into the input jack of the M80. I could sort of regulate the sound using the volume control of the first amp.
If I can't fix the M80 could I just buy a used preamp and plug it into the M80 this way? Would I burn out one of the two by doing so?
I wouldn't be surprised if the input jack just needs a re-solder job? It is very common for these Fender amps to have broken or cold solder joints on the input and output jacks.
You'll have to pull the whole PC board out which is not difficult but time consuming. Make sure you mark the cables before you remove them and just take your time.
Is the chorus on these amps supposed to be on both left and right outputs?
I have one with chorus only on the right output, don't think it's correct.
Enzo, I emailed you for a schematic if you have one, thanks.
Look at the mono effects loop, which is the preamp out. After C31, the dry signal goes to U6B and on to the left power amp, and it also branches through the chorus circuit and back to U6A for the right PA. U8A switches the R PA between that chorus or the dry signal.
Doesn't work that way Robby. I am happy to send it, but please follow the instructions in the post above yours.
Also, since there are several M80s, please send me the complete model name, and IMPORTANT list the items across the control panel in order. This will ID your amp for me.
I am on a dial up and don't want to send four large files
Hey everyone, I stumbled upon this site via a google search for an M80 schematic. I ordered a schematic from Fender and received a lot of fluff information and 1 of 2 pages of the actual schematic. I noticed there are no power electronics on my schematic and was hoping someone had the second page. The page I have is 037023. The M80 I have is the head to a half stack with matching speaker cab. Can someone help me out? Thanks a lot.
