While re-capping my 200s I noticed that on the schematics I have it shows two .25mfd caps coming off the 6AN8 tube, but I can't find any of that value in my amp. What's up with that?
200S schematics
Yes the Sunn 200S and it is the same schematic you posted.
Coming off pins 1&3 on the 6AN8.
It was suggested that they are the Black Cats that are up by the KT88s, but mine are .1mfd @ 400v and I have a total of 3 of those
Mine is a '67, by the way
Now I'm whicha.
0.25uf phase inverter coupling caps.
I see two.
Where is your third one.
That 0.25 value is pretty obsolete.
Nowadays it would be 0.22.
Link:715P22454MD3 Vishay/Sprague Polypropylene Film Capacitors
You can still get new .025uf caps, but I think the only ones I know of are the Polyester version of the Orange Drop...225P's I think. I saw some a couple years back at AES, but I just looked now and don't see them. Solen makes a .27uf which is close, but a Solen will sound different than what is in the amps for sure. I wouldn't replace the coupling caps in the amp unless they are leaking DC to the following stage. The electrolytics need periodic replacement but not the coupling caps. The brown blob ones that Sunn used could stand replacement though. They usually still function fine but were lousy caps from day one with high ESR. These are the same as the dreaded brown blobs that Fender used in some of the Silverface stuff. Pretty much any caps are better than these.
Greg
Interesting they should change the values. I have been collecting pictures of the chassis on other peoples 200S' and it seems those black Cats (at .1uF) are pretty common. That's what originally made me wonder about the .25uF call out. The Dynaco Mk III has the same .25uF call out.
I never throw anything away (it's a curse) so I'll try the new caps I have and if they don't sound right I can put the old ones back in. The brown ones do look a little sad.
Originally posted by Greg_M View PostInteresting they should change the values. I have been collecting pictures of the chassis on other peoples 200S' and it seems those black Cats (at .1uF) are pretty common. That's what originally made me wonder about the .25uF call out. The Dynaco Mk III has the same .25uF call out....
Regards,
Tom
