Y2 Class EMI Suppression Capacitor - "Death Cap"
  • Y2 Class EMI Suppression Capacitor - "Death Cap"
    When I re-capped my 1st Acoustic 370, I replaced both of the old .047uF caps on the primary side of the PT (C401 & C402). One goes across the power switch and the other has one end tied to ground & the other end is switchable between the neutral or the hot leads of the incoming power cord. At the time, I ordered 2 PME271Y547MR30 Y2 Class caps from Mouser. The one across the switch could be an X Class, but I decided to just use 2 identical caps for simplicity.
    Now, I've got another 370 to repair & I can't source this cap anywhere. All the usual outlets show it as out of stock. Since most tube amp achematics I look at have identical or similar caps, I'm wondering what you guys typically use for these caps? Thanks.
    ST in Phoenix
    Acoustic 370 Schematic
    Here's the schematic.
    ST in Phoenix
      Try Just Radios.
      Nice link to the whys & wherefores of safety capacitors.
      Link:Y2 Safety and Interference Suppression Capacitors for Tube Electronics
        Thanks for the source. I don't like just removing them & I don't trust the old ones in this application.
        ST in Phoenix
