"Glastic"for flatwork anybody try
  • "Glastic"for flatwork anybody try
    Found this stuff at the Dynamo shop,it`s .09 thick red color composite plastic and fibreglass.Same thickness as my factory jazz flat`s.Don`t know how it machines yet,or how it can take heat but it looks like it should work?Also lookin for suggestions regarding rod magnets,longest I`ve seen on net is .688",my factory jazz bass are -.780"tX.185d.should I just keep searching or make my bobbins less tall.thanks for the welcome NightWinder
    Originally posted by RichS View Post
    Found this stuff at the Dynamo shop,it's 0.09" thick red color composite plastic and fibreglass. Same thickness as my factory jazz flat's. Don`t know how it machines yet, or how it can take heat but it looks like it should work? Also lookin for suggestions regarding rod magnets,longest I`ve seen on net is 0.688", my factory jazz bass are -0.780"t x 0.185"d. Should I just keep searching or make my bobbins less tall. Thanks for the welcome NightWinder
    It ought to work, but may be overkill. Drilling and sawing will require carbide tools - this is a form of fiberglass. If I understand, it is (or can be) supplied in the partially-cured state, and so can be bent into form, after which it is baked and becomes hard. Probably used for making insulation shapes for motors.
    Go to http://www.glastic.com/ and look around.
    It isn't clear if glastic is any better for bobbins than printed-circuit board materials.
      I see it's available as an I-beam extrusion, perhaps that could be the foundation for an easy custom bobbin?
