Results 1 to 5 of 5
Thread: Burning resistor on my Road 220
    New Member
    Nov 2010
    3
    0
    I have a road 220 100 watt bass amp, and resistor #22 keeps catching fire!
    Is there a way to figure out what the heck is making it do that? I don't want to blow another one, and I really want to fix this amp.
    I have this funny feeling that tells me I am in over my head, but I really want to know if I can just replace a couple of transistors or if the situation is worse, and if there is even a way to tell. Forgive me for being an amateur.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    33,438
    Received: 2,522/7
    57
    Get out your meter and start checking transistors.
    New Member
    Nov 2010
    3
    0
    Forgive my noobness, but do I pull them off and check them or does it work while they are soldered to the board? What exactly am I looking for?
    33,438
    Received: 2,522/7
    57
    You are looking for transistors or diodes that are shorted mainly, but also ones that are open. Test the parts while they are in the amp first. If you find a shorted one in the circuit, then remove it and test it by itself. it is possible the part is OK and something around it is shorted. If it tests not shorted in circuit, then it is not shorted. Nothing in the circuit can make a shorted part look not shorted. Opens are a little different, if the part seems open, it probably is.
    New Member
    Nov 2010
    3
    0
    Thank you so much for the very informative information, Enzo.
  1. Road Lead 220
    By Euthymia in forum Schematic Requests
    Last Post: 11-30-2017, 05:19 PM
  2. Mesa Road King Schematic any one????
    By wyomingrocks in forum Schematic Requests
    Last Post: 04-19-2012, 08:40 PM
  3. Road 440 LEAD
    By lowell in forum Schematic Requests
    Last Post: 10-20-2010, 11:51 PM
  4. Road Cases.
    By Hella1hella in forum Guitar Amps
    Last Post: 10-11-2010, 07:21 PM
  5. On the road need to fix an apm
    By FORTH YEER in forum Music Electronics
    Last Post: 08-04-2010, 08:13 PM
Tags for this Thread
