Need Help
opto-isolator, how does it go in?
It has the two longer leads and dot (should be optical right)
Other end short leads (should be resistance side right)
1. I "think" resistance side should go closest to tone knobs.
2. I "think optical side goes closest to back of amp?
Am I right?
I do not see a dot on the current opto.
*As amp sits now, the two solder connections closest to vol/tone knobs, one is grounded, the other is connected to Intensity pot.
Please advise.
House current 127 volts. Verified with second meter Pete.
Have 1 ohm resisters and getting ready to solder them in.
Thanks for jumping in here Dave, but you will have to dumb it down quite a bit. I just started reading about this tube amp when I started this thread. I am taking baby steps here, but hope to learn something, and at the same time fix a couple small problems with this amp.
Am I right?
Please advise.
