Hello
I have BF SR Fender.
I think/assume I only have a power tube balance pot. I read on forum to balance this, take tubes out and measure pin 5 to ground on both PT sockets, and it should be around -55 VDC.
Questions
1. You only take power tubes out correct, the preamp tubes do or do not have to be taken out, I assume leave the preamp tubes in?
2. You guys ever use https://ssl.eurotubes.com/cart/index...ategory_id=109
This is eurotubes bias probe ($25) and cheap digital meter $10? I only have a few amps to do at home. I know it is not the best, but looking for a cheap way to set bios.
Thanks for any input
Questions
