yamaha em150 p.a. mixer
  • yamaha em150 p.a. mixer
    Hi all
    myYAMAHA EM 150 P.A. MIXER has a problem
    everything functions as it should except Left Channel Monitor Output
    is dead
    I have tried different cables etc. but no ouput
    all other outputs function well on both channels
    all inputs function correctly
    the amp runs at full power no problem to main speakers
    I do not have a schematic for this mixer so I am not sure if the monitor circuit has it's own pre-amp sectiom which is causing this problem on the left channel
    the connection wire on terminal at jack output is solid and shows good connection to board and cable output wire
    any help would be welcome
    thanks in advance
    regards
    robgrif
    Please verify that you have signal on the dual/ganged Monitor Out potentiometer.
    Without a schematic, your best bet is to trace out L & R from the jacks to the board.
    There is most probably an identical circuit for L & R.
      yamaha P.A.
      Thanks for the quick reply
      I traced back the left channel as you suggested and found the offending transistor in the preamp circuit showing short b to c no other problem seemed to be present
      replaced it with nte 199 substitute could not find any other brand locally supplied
      and the monitor left channel fired up
      Thanks and Happy Holidays to all
      regards
      robgrif
