I have been searching for answers three days now, but I don't think I got my questions answered. Hence, yet another 5F2 thread. I have two things I am wondering about, and I did enough research to make some plans/assumptions. I'd appreciate input on my assumptions.
1) read here that for a single-ended amp like a 5f2, ss vs tube recto makes no difference other than voltage (a 5Y3 drops a good bit of it). I have some 1n4007's, so I think I might use these for the rectifier. I also have some 22v zeners in stock to handle the extra voltage. I was going to just use two diodes and wire em up just like the tube recto only on a little board. 1n4007's seem to be rated at 1a/1000v which should be PLENTY considering I will be using a 1a fuse. All correct? Is there some reason to use a tube recto?
2) intrigued by the idea of being able to drop a 6L6 into this thing. The OT I have is 15w, has a 5k primary and a 6k primary. It has 4, 8, and 16 ohm taps. The speaker I bought is 4 ohms. Using a 6L6 isn't a primary concern for me. But it seems like I could just switch out the zeners to get the higher voltage and then plug the 4 ohm speaker into the 8 ohm tap (to get 3k on the OT primary which would be better for a 6L6 than 6k). Thoughts on this?
My sources:
http://music-electronics-forum.com/t12634/
Single-ended 6L6 amps - AMPAGE Archive
5F2 circuit sounds great in 6L6 format - Telecaster Guitar Forum
My sources:
