I am trying to repair a Koch Twintone 1 .
the 1st problem is the amp has very low volume. I have checked a lot of things :
swapped all tubes
bias ok at 33mv
all voltages look normal at all tubes
B+ is 445V
power soak resistor ok (even tried unplugging that soak)
re-seated all 3 op amp chips
cleaned all jacks
cleaned all pots
I didnt find any open resistors
the 2 screen resistors are ok
the amp still has low volume - sounds like about 2 watts instead of 50 w !
One thing i tried-- i ran the koch effect SEND to another amp and it had FULL loud volume . So that means the problem is somewhere AFTER the FX return .
Could it be one of the IC chips ? or transistors (T1 , T2) ?
Problem #2 might be related , the amp has a loud hum. Even with all volumes on 0 . The hum goes away when the phase inv. tube is removed ---this might be related to the low volume problem
trying to attach the scem here
swapped all tubes
bias ok at 33mv
B+ is 445V
cleaned all jacks
cleaned all pots
