strange noise in my 66 blackface fender twin not re issue
  • strange noise in my 66 blackface fender twin not re issue
    hi again every one,
    this recapped twin has been operating perfect for some months
    but now
    there is a strange distortion that follows every note
    sounds kind of like a flange pedal with some oscillation
    the the amp sounds super in the attack but the the sustain turns into some kind of alien sound
    you can hear it real good as you back the guitar vol off
    happens on both normal and reverb channels and no amount of poking or prodding seem to affect it
    any thoughts any one?
    Most common cause of this type distortion is a bad first filter cap. Probably one of the two caps in series is bad or has become disconnected.
      mmmmmmmm
      these were a new set
      got them at vintage amp south on ebay
      get lemons some time i guess
        And just for science, play the amp chassis through a different set of speakers.
          A resistor may have drifted way off and made the amp prone to parasitic oscillation.
          A bad connection, eg dry joint, loose tube socket female contact.
          A bad tube.
            Record that sound and make a $million. Kidding, If those tubes are Sovtek WXT get them outta there. Could be several things but a bad cap or connection to one would be up there on my list.
            KB
              Originally posted by chris61 View Post
              mmmmmmmm
              There have been lots of threads here and on other forums telling about bogus electrolytics. They have brand names and look perfect, but if you open up the can you can find all sort of junk inside. Often smaller value or voltage, cheap caps. The symptoms are often similar to what you described. The amp works fine for a while, but then goes south.
                Bad preamp or phase inverter tube, including loose or dirty sockets.
                Don't believe everything you think. Beware of Rottweiler. Search engines are free.
                  damn it was one or both of the speakers
                  I pluged it in to my mesa EVM cab and the sound cleaned right up
                  what do i know now?
                    what do i know now?
                    Find a good re-coner.
                      Science, you win this time...
                        also
                        using an off board cabnet the reverb dosen't squeel win you turn it over 6
                        could that be the fault of a bad speaker
                        or just an issue with a combe cab?
                          happy new year to all
                          and thanks for your help!
                          this old twin always sounds better after coming here
                            How is the reverb tank mounted? In a bag? Screwed down? Which way up?
                            Try taping thin card or other board over the open side, wrapping it in a thich towel, and letting it sit loose on the bottom of the cab, away from the baffle.
