aby question
  • aby question
    hey guys
    i've been told by "they" that you cant use an aby switch on the output of an amp to change speakers. i asume its because of the large current flow in the output of a tube amp, but i have a number of solid state and hybrid amps that i believe have a small current flow in the output?
    Can i use an aby in the output of theses amps to switch speakers?
    thanks
    Clay
    I believe the reasoning goes as follows.
    Tube amps can be damaged if run with the speaker disconnected, even momentarily.
    When you operate an ABY switch, there is a brief instant during which the amp is connected to neither speaker.
    With solid-state amps it shouldn't be a problem. With hybrids it may or may not be.
