I just acquired a MG100DFX in great condition except it for an intermittent volume drop. At startup, the amp is fine. After about 15-20 minutes of playing (I've only tested at low volumes), the volume drops lower and stays there. I can turn the amp off, then back on and the volume resumes. The condition is the same on both channels in all settings (clean/crunch, OD1/OD2). Based on other posts for this and other amps, I've tried the following with no luck:
-Cleaned all pots and jacks with electronic cleaner (from Radio Shack) The interior is very clean in appearance to begin with, and it looks like a well maintained amp in general.
-Patched the FX send and Return with a single patch cable - no difference. Volume problem persists.
-Inspected for bad solders/loose connections. Everything looks fine.
Any help or suggestions would be appreciated. Thanks in advance.
