It's the first input transistor. It's round with a black dome top with white band around it with numbers that don't seem to make sense. 3 pins with a Teledyne insignia and NO indexing marks. I can't find any data sheets with the pinout? It was mounded on socket that was broken. I was gonna solder it directly on the board? Any comments are welcome.
"71" Coliseum Bass amp... Need trasistor pinout for 2n4304 small signal FET
Thx for the info. It appears the transistor is bad. I also fed a signal from my signal generator traced it right to the transistor but nothing is being passed. The voltage is a little high on one side (instead of 23vdc, it's 30). But the transistor has proper voltage. The schematic is at www. richbriere.com/the_sunn_shack.htm. It's the schematic of the month. Any subsistutes?
Are you sure the JFet is installed correctly?
The drain to source should be normally on.
The gate will "pinch" it off.
Jumpering D to S should get you going, temporarily.
I do not know the function of this device in the circuit.
It appears to be an input limiter.
Try a 2N3819 as a replacement.
I think any 30 voltJfet will work.
Against my best instincts, the 2N4304 crosses to a NTE133.
Link:NTE ELECTRONICS|NTE133|N CHANNEL JFET, -25V, TO-106 | Newark.com
Added: Fairchild crosses the 2N4304 to a PN4303
Link:PN4303 Fairchild Semiconductor JFETAttached FilesLast edited by Jazz P Bass; 01-19-2011, 08:19 PM.
I'm really green at knowing what to sub and your help is great. I did see a reply from Enzo that he said, like you, that several subs would work. He was recommending a Motorala 2n5458. I have to put in an order to Mouser this week. What would you choose?? Not to put the pressure on you... But this in not my in data base (brain). I better test the other transistors before I order, eh? You up for this project??
I would go with Enzo on this one.
2N5458.
Link:FindChips.com Online Electronic Component Distributor Inventory Search
This site will find the part for you.
I just pulled a JFET out of a Concert Bass I have open. Looking at the bottom of the part where the leads come out, position the part so the two leads that are farthest apart are at the top and bottom and the third lead is to your left. The Gate is the top lead and the other two are Drain and Source. You can interchange the Drain and Source, the part will work fine either way. Between the Drain and Source you should measure about 500 ohms and the Gate will give you a diode indication to either Drain or Source.WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
Originally posted by 1ampman View Post10meg in 1 direction and open in the other...WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
The transistors are OK with the basic mulitmeter checking. So I'm looking at my 23 volt supply/dropping resistor. But CR101 & CR102 little glass diodes with NO markings on them could be the problem. Anybody know what they are and what would sub for them??? I get 32v at the correct point but the 23v is 32v (not dropping down).... This is all on the first transistor.... ???
