Is the 5E3 sound easily reproducible without the proper components?
  • Is the 5E3 sound easily reproducible without the proper components?
    Hi everybody!
    Well, i want to make a 5E3 in head form. Well, i have two transformers from an old revox valve reel to reel, 6or 8k output with a hefty core (looking as big as a bandmaster trany) and a double C cored power, pushing above 350vdc IIRC. But there's no 5V for the rectifier., so i could make a no tube recto 5E3, carbon film resistors, and polyester or polyurethane caps. With thoses components, do you think i could have a decent tweed sound? And finaly, is the tweed sound for me? Knowing that i live BF and SF deluxes ?
    Sure, you can just use some old wooden kitchen spoons and plastic spatulas along with some tupperware bowls and make a dead ringer tweed sounding amplifier.
    Uh, the simple answer is no. As to whether or not the tweed sound is for you, that is a very complicated question. You should really try to find a tweed deluxe original or clone somewhere at a music store and answer that question for yourself.
    Tubes transcend solid state
      Hi Anon.
      Thanks a lot for the reply. As for finding a tweed, well, over here they're as rare as chicken's teeths. Components wise, i might not be too far. I have a pretty big stack of OOS caps and resistors that i can pull from. Very nice 6V6 from Fivre. The point where i'll lack, is the tube rectifier. Has anybody ever built a nice sounding tweed with solid state recto?
      Bye.
      Max.
        Interesting build issue. I wonder how close you could get to tube rectifier goodness by using a sag resistor in the power supply? (100R wirewound 10W?) Or maybe one of those SS 5AR4 plug-in replacements since they don't need filament wires?
          Nice smartass remark for your first post. So you signed up just to insult Satamax? He's a good man, a good contributor to this forum, and a nice guy.
          Too nice to call you an asshole, but I'm not, Asshole.
          Stop by my web page!
            Thanks a lot Regis but, don't worry, he's just some flamebait. I didn't even bother replying to his sarcasm.
            Bye.
            Max.
              Bye.
              Max.
              Max, there is a great thread about Blackface vs Tweed over at the Gear Page.
              Here is the link.
              I'm not that familiar with Tweed tone either, so it had some good info.
                Why not use a Weber copper cap? They don't need the filament wires, they do sound "good" (I'll certainly vouch for that), some even say they don't hear enough difference to justify a tube.
                I haven't had any reason to change/replace them in any amps I've built with them/fitted them to, for tonal reasons. They are standard fitment in Weber tweed kits.
                  This brings me to another question: I read somewhere that if you use a solid state plug in rectifier replacement instead of a tube rectifier you have to have a standby switch on the amp. If you don't, the startup jolt damages the tubes somehow, stripping the cathode maybe? I can't remember. I have a Kay 720 that has a 5U4 in it and was thinking about experimenting with a ss rectifer, although the amp sounds really good as it is after I did a couple of mods on it.
                  thanks,
                  regis
                    thanks,
                    regis
                    Never mind, I went to Teds site and he sez you don't need a standby switch with his copper caps. Maybe other brands you might have to.
                      Hi everybody!
                      You might be closer to a 6L6 tweed amp with this if the trannys you are thinking of using are very large, but it will still sound tweedish.
                      The 5E3 used some fairly light weight trannys as compared to hi-fi equipment.
                      The OT only weighs about 1.5 lbs for comparison to what you have.
                      The B+ rail does sag a little under full power but the 5E3 runs it's power tubes so high in idle current that the actual power supply doesn't sag as much as some would think once the power tubes are fully hot.
                      However, you can use a 47 to 100 ohm 5 watt resistor after your solid state diode rectifier to add a little sag to the B+ rail to simulate some sag.
                      You can also use a 6CA4/EZ81 rectifier tube right from the same 6.3v filament string the rest of the tubes are using if you have enough extra current available.
                      Bruce
                      Mission Amps
                      Denver, CO. 80022
                      www.missionamps.com
                      303-955-2412
                        Hi Regis,
                        Ideally, you would only forego the standby switch if using a slow start up rectifier like 5V4 or 5AR4/GZ34. Even when using a 5U4 or 5Y3 you still get voltage spikes & cathode stripping on "turn on". This didn't stop manufacturers from fitting them to amps without a standby however (like your Kay). It wouldn't cause any kind of failure under warranty, just wears the tubes a bit quicker.
                        Solid state diodes do not have a slow start up, Weber copper caps are claimed to.
                        When going from a rectifier with a big voltage drop (5Y3, 5U4) to a rectifier with a smaller voltage drop (GZ34) or solid state diodes (no drop) it is wise to check that operating voltages for tubes & caps are not exceeded and that the bias current does not rise beyond sustainable limits.
                          Hi everybody!
                          Bruce, thanks a lot for your reply, i forgot about 6V3 rectos IIrc, i might even have two 6V3 taps. I know i have some weird ones like 24, and 37something volts. Might have been for the motors. I gonna give it a try anyway, and see how it goes. Is it risky to run a chinese 5AR4 on 6V3? Or may be use a wall charger trany, if i can find a 3V5 and rectify it.
                          Bye.
                          Max.
                            No 5V tap
                            The other option would be a separate 5V Power transformer. Here's one at Radio Spares that'd do 4A at 5V:
                            http://rswww.com/cgi-bin/bv/rswww/se...0&cacheID=ukie
                            Remember....these ARE the good old days.
                              Assuming you have a 6.3v winding and the PT is actually 700VCT tranny (with a center tap), use an EZ81/6CA4 rectifier.
                              The B+ voltage in your build might be pretty high for a classic tweed 5E3 tone.
                              Use polyester coupling caps and maybe voltage dropping 5 watt zener diodes in the hi voltage center tap to ground in order to lower the B+ a bit.
                              Bruce
                              Mission Amps
                              Denver, CO. 80022
                              www.missionamps.com
                              303-955-2412
