Has anyone ever tried it? I'd love to hear about your experiences and results if you have.
Square magnet wire
IINM, hex core wire was the shiznit for extreme spec chokes at one time. Be absolutely bonkers to try to stack that perfectly in 42ga, sorta like stacking BBs. Nevermind that the added inductance is exactly the direction we're trying to avoid usually.
Originally posted by Ronsonic View PostBe absolutely bonkers to try to stack that perfectly in 42ga, sorta like stacking BBs.
Square wire is used when you need to maximize the copper in the available coil area. As mentioned above, you need to take special care to align the square sides to each other as you wind. The final result is a coil with less wasted empty space in the stack and the ability to fit an equivalent number of turns of heavier ga wire into a given space than would fit with standard round wire. This is usually only of benefit for power magnetics. Edge wound rectangular wire speaker voice coils are another application.
Cheers,
Tom
