Results 1 to 18 of 18
Thread: roland tr-808 drum machine = vintage 80's
    Senior Member Mars Amp Repair's Avatar
    Sep 2006
    Englewood, CO
    812
    Received: 1/0
    Hello folks,
    has anyone found a good replacement for the start/stop & Tap switches for this unit?
    They are fairly specific momentary push switches. these units are now very sought after and are selling for around $1500 at this point, so I want to make this look as original as possible.
    The switches are sealed and drilling a hole in them to get deox in was no help.
    Mouser has nothing like it that would be the same shaft size as the knob.
    thanx, glen
    Senior Member mozwell's Avatar
    Sep 2009
    Australia
    645
    Received: 4/0
    Hi Glen
    No idea as to the switches, but ther service manual for the 808 is here Audio Roland : Service Manual free download,schematics,datasheets,eeprom bins,pcb,repair info for test equipment and electronics
    The manual for the 606 is also there
    Clone information for drum circuits from the TR808 is here
    eric archer . net 808 clones if you want to build a triggerable sound module for each drum sound.
    I know its not what you are after, but maybe someone is interested.....
    Cheers
    Andy
    3,757
    Received: 115/2
    Given: 11/0
    Smallbear Electronics carries several different momentary switches for Boss and Ibanez pedals. They might have something similar, if not identical.
    Sep 2006
    Englewood, CO
    812
    Received: 1/0
    Hey thanx guys,
    I actually was able to get these little buggers apart & then coat the little carbon button with that Caigcoat stuff. It works pretty well. We've used it on keyboard sensidome strips for some of the Korgs where the strip is no longer available.
    See pix attached...thanx again all...glenClick image for larger version.
ID:	12692Click image for larger version.
ID:	12693Click image for larger version.
ID:	12694Click image for larger version.
    Supporting Member
    Texas
    297
    From the pictures you posted, the switch looks a lot like the bypass switches used in the Boss pedals. Get a few DS-1's and rob the switches out of 'em.
    New Member
    Feb 2011
    2
    Interesting
    Mars, how did you get the switch apart, and how did you get it back together? I'm facing the same problem.
    Sep 2006
    Englewood, CO
    812
    Received: 1/0
    Hey guys, thanx for the suggesions. they do look like the pedal switches from the Boss variety.
    As to how I got them apart..it's a bit difficult to determine from the pix I posted, but on either corner on the bottom of the switch, there are two larger looking post 'indentations'.
    What they did was melt the top of these posts into the bottom cover of the switch. If you take a drill or possibly an exacto knife & dig-cut out the melted 'muffin top' portion of that post, the swtich will come apart.
    I orginally tried to cut the post off through the separation between the top & bottom of the switch, but quickly determined this was a problem & the switch wouldn't align correctly when I attempted to put it back together.
    the 3rd pic in my post above best shows the tiny posts. I epoxied the switch back together once I was certain the coating would hold. I did blob the coating on fairly thick, as the switch puts a fair amount of pressure on the little carbon button & I was concerned a thin layer would wear off.
    Take it slow & cautious & it's really too difficult...you only get one shot! thanx, glen
    Sep 2006
    Englewood, CO
    812
    Received: 1/0
    WOW. Yes, Smallbear does have the identical switch...for only $1.95.
    Switch - SMK for BOSS DS-1
    I'll definitely go that route next time...thanx, glen
    Sep 2006
    Englewood, CO
    812
    Received: 1/0
    One Caveat...
    I just noticed I do have some of what looks like this switch from Smallbear in stock. I tried them & as I recall, the height & size of the actuator is slightly higher & larger, so some modification will be necessary to get everything to work properly.
    The knobs on the TR808 have a cross ' + ' shaped hole in them that has to fit the ' + ' shape of the actuator on the switch. The switch from the Boss pedals is slightly larger than the knob on the TR808, so it might be a bit tricky to get it to fit & still look ok.
    As I recall now, I decided to go the 'repair the switch' route to keep the Tr808 as original looking as possible a well as it looked like more time involved. These things are very much in demand right now & are selling for like $1500.00!
    I do think however that this could be accomplished...thanx again, glen
    Sep 2006
    Englewood, CO
    812
    Received: 1/0
    Sorry...I just remembered further.
    I disassembled one of those boss switches with the idea of exchanging the rubber dome contact piece inside...they are completely different inside...the Boss switch uses hard metal contacts & not that rubber dome piece that the original has in it.
    Just trying to save ya some time here....glen
    Sep 2006
    Englewood, CO
    812
    Received: 1/0
    Better pic of switch:
    See attached. you can see the impressions of the top of the posts on the bottom of the switch. glen
  12. #12
    New Member
    Feb 2011
    2
    Thanks!
    I managed to do it, though it was hard to get it back together - my switch was completely sealed. I took a scalpel to the seam, cleaned the contacts, used Caig Coat as you describe, then epoxied it back together. It's now good as new, but I'd hate to have to do it again - I'm still looking for spares...
  13. #13
    New Member
    Feb 2011
    Melbourne Australia
    1
    Service manuals,part numbers & a second type of this ALPS keyswitch
    I tried the dismantling and epoxying approach in the past, but
    did not succeed in making the epoxy strong enough. I used a
    little fine wet-and-dry paper on the rubber contact, and I
    think I used some isopropyl alcohol and then some fine wet-
    and-dry paper on the metal contacts. In that case, I
    installed some different kinds of switches and buttons, which
    was far from ideal.
    Recently, I was able to obtain two switches which were
    proper replacements, from an unused MC-4 keypad panel.
    These were mechanically entirely compatible, though the
    details of the body were quite different and the shaft is
    black, rather than white. Both types had the ALPS oval
    trademark on the bottom. The new ones can easily be
    unclipped and clipped back together. So if their rubber
    contacts start to fail, it will be a matter of desoldering them
    and unclipping the side parts to clean the contacts, rather
    then replacing the whole switch.
    I was wondering what the ALPS part number was, but my
    only copy of the TR-808 service manual was an old
    photocopy, missing the part numbers. Today, thanks to this
    forum, I discovered Eric Archer's TR-808 clone drum sound
    page: eric archer . net 808 clones and was
    very happy to find an excellent scan of the TR-808 service
    manual there. This is "3rd printing June 1986 C-2", so I guess
    it is the final version. (The previously mentioned service
    manual at fileshare.eshop.bg was a .zip file in two parts and I
    couldn't easily find a way of unzipping the two.)
    Unfortunately there's no ALPS part number in the service
    manual. Just listings of "KED1001" for the Start/Stop switch
    and button combined, and "KED10903" for the Tap switch and
    button. These have surely been out of production for 25
    years or so, but its always good to have a part number. I
    have some ALPS catalogues from the late 1980s and early
    1990s, but I can't access them right now. If I find a proper
    part number for these switches, I will post it to this forum.
    Googling KED1001 lead to VINTAGE PLANET - Parts Service for Vintage Synthesizer Repair - Roland Parts
    but they have none in stock. It also lead to another copy of
    this beautifully scanned service manual:
    http://manuals.fdiskc.com/tree/Rolan...e%20Manual.pdf
    This directory: Index of /tree/Roland has a bunch
    of Roland service manuals. Stepping back to the tree
    directory, there are directories for many other musical
    instrument manufacturers - a treasure trove of manuals,
    including for some obscure machines.
    There is an MC-4 manual, from 1982, which is a little after
    the 1981 date at the top left of the TR-808 manual. So my
    guess is the MC-4 is somewhat later and this use of the
    black-shaft switches indicates that ALPS changed their
    design from the heat-sealed white shaft approach to the
    side-clip black shaft approach. Unfortunately, there's no
    ALPS part number for the keyswitches - just KEH4AO06 for
    the 10 key assembly, presumably with buttons included.
    I think, with care, it may be possible to reassemble the old
    switches and make them strong enough. I think it would
    require epoxy on the outside of the case, with some kind of
    reinforcing to the PCB, which would make it all hard to
    dismantle in the future. These switches can get a lot of
    sideways force, so I think the case needs to be well
    supported since just epoxying the two pins is not, in my
    experience, strong enough.
    - Robin
  14. #14
    Sep 2006
    Englewood, CO
    812
    Received: 1/0
    Well that's great thanx for all the research. I do have the original manual as well am Roland authorized, so I can still print it from their authorized website. Yes, no Alps number.
    I forgot that the switches were somewhat fused together. I was using a very sharp long exacto knife in the seam to rock it back & forth & break the seam. It wasn't fused that badly.
    As for the epoxy...I used the 5min JB Weld (would never use the other semi-clear crap). I put a slight amount in the seam before I closed it up & I'm tellin' ya, this weld will not break.
    the switches afforementioned that go in the boss pedals probably could be modified to work, however they only have 2 connection pins as opposed to the 4 of the original (for strong mounting given the leverage that big knob has) & as mentioned the 'Cross' shaped actuator is slightly larger than the original...wouldn't be as big an issue if the knob also had a cross mounting in it.
    If anyone ever enounters a switch that will retrofit easier...let's post it...
    thanx, glen
  15. #15
    Aug 2006
    424
    Received: 2/0
    Given: 24/0
    I just midi to a cheap keyboard and I get double 2 snares BD, CB HH, ect.Alot easyer to play live then tapping on a little keypad.Not wear it out.Istarted getting some distortion on the snare,with the Keyboard it is gone...
  16. #16
    New Member
    Feb 2011
    1
    808 parts
    I got some replica 808 parts from this guy on ebay. eBay My World - chipforbrains He usually has remanufactured switchboards/pcbs and knobs that are super high quality.
    I also got a full new replacement fader pot set for my sh-101. My 808 start button was also broken but instead of fixing it I opted to get the pcb with leds and switches already built. It was like $100. Anyway good luck I love my 808!
  17. #17
    New Member
    Feb 2011
    1
    I also got the idea somehow..
    [URL="http://music4hiphop.com/"]Hip hop music[/URL]
  18. #18
    Sep 2006
    Englewood, CO
    812
    Received: 1/0
    New site for some discontinued keyboard & tr808 parts.
    New site for some discontinued keyboard & tr808 parts. Need a Fix? - Technology Transplant
  1. Need advice fixing Boss Dr.55 drum machine
    By methodofcontrol in forum Music Electronics
    Last Post: 01-18-2018, 11:20 AM
  2. Boss DR55 Drum Machine issue - Electronics problem?
    By Stakker in forum Music Electronics
    Last Post: 09-09-2010, 11:05 AM
  3. Custom drum machine rack photos
    By captainlee in forum Music Electronics
    Last Post: 04-30-2010, 04:23 AM
  4. Computer drum machine???
    By Satamax in forum Fun with computers
    Last Post: 06-05-2008, 10:48 PM
  5. a good drum machine?
    By MarkXXX in forum Fun with computers
    Last Post: 03-15-2007, 11:58 AM
