Embarrassing question: Line 6 POD X3 Live and a simple question
  • Embarrassing question: Line 6 POD X3 Live and a simple question
    Ok, this is embarassing....a kid brought two POD X3 Live peddle boards to me at my home this afternoon with intermittent stomp switches.
    Sure, easy, no problem....er.....How doe the damn thing come apart. I've removed all the exterior hexhead screws that look as if they should separate the top and bottom of the case, and the bottom cross point screws...but nothing seems any less firmly attached than when I started.
    What is the secret?
    Edit: Never mind, I just needed a larger sledge hammer...Literally a rubber mallet tapping in the right spots and it popped open.
    It is at this point you discover that you removed screws that you would rather have left in there.
