JCM900 Preamp + AX84 Single Ended with channel switching
  • JCM900 Preamp + AX84 Single Ended with channel switching
    I'm building AX84 Power Amp :http://www.ax84.com/static/corepower..._Schematic.pdf
    clean channel preamp : http://www.ax84.com/static/corepream..._Schematic.pdf
    and JCM900 preamp for lead channel: http://www.heavil.ru/cxema/marshall-...preamp.gif.jpg
    I would like to have channel switching just like JCM900 had but on this power amp. Original schematics use multiple chips etc. but i want to do it old school without them. I'm thinking of using relays or opto-coupl, but i don't know where to put them in the circuit. I was thinking of using "clean channel" as first on input and then with a switch turn on the "lead channel" section. I looked into it in older threads and googled it but didn't find sufficient data on this. If someone would be so kind and help me out
    Dear Mastersamo: your guitar signal should go into both preamps, which then will run "in parallel", although you'll use either one or the other.
    Since you have another, completely independent clean preamp, you can switch between them using Led_LDR or Relays; FETs or CMOS gates aren't well suited for the high signal levels usually carried by tube preamps.
    Remember to have an extra switch to kill gain on the distorted channel (besides switching it off) so as to avoid noise feedthrough/crosstalk when unused.
    *This* version of JCM900 you link does not have any switching.
    The one which does, is a *very* different beast, and might be considered a giant SS distortion pedal, driving a tube power amp.
    Yes, it does have a tube, but since it does not distort, it doesn't add much to the final sound .
      Hmmm, thanks J M Fahey on your comment. Do you think that it's a waist of time trying to build this JCM900 preamp and should choose another preamp? If so could you name me some pedals/preamps that have that JCM900 sound. But i don't want solid state kinda pedal, so low-or-even-ANY solid state stuff in pedal, i'd like to see it full-tube, even if i don't get that exact Marshall-Crunchy-Lead sound. Should i signal that's going into preamp that's not being used ground or just let "floating in the air"?Also i would like to know if i should go with the KT88 or EL34, since this is gonna be driving a 1x12" i think that kt88 will give me more bottom-end and closer to Marshall-sounding amp even though the use EL34's. Pls help me out
        No, what I told you is that you should not build the "regular" SS preamp; the one you linked to is the less common, non switching "good" all tube one.
        I don't even understand why they carry the same name.
        You need at least a DPDT relay; the ones with 6 contacts, same as "true bypass" switches.
        I've drawn a block schematic to show you:
        You see the relay coil drives two spdt (single pole dual throw) switches, where the center pin touches normally the upper one by spring pressure (nc= normally closed); when the coil passes current it atracts the leaf switch, opening the center_to_top contact and closing the center_to_bottom one.
        We can use this to do a lot of things, just be creative.
        In this case, (as drawn) , the upper switch normally selects the upper (dirty) preamp into the output jack; the lower (clean) preamp is disconnected from it.
        If you activate the relay, both sets of switches change; the upper one selects the clean Pre, the Dirty one gets disconnected.
        Isn't that enough?
        Usually no, remember input jack goes to both preamps all the time.
        Although you have not selected the dirty one, it is still working full blast, doing all kind of nasty things to poor guitar signal
        This very loud and distorted signal can easily get into the clean channel; you'll hear the clean sound mixed with a faint but annoying distortion in the background.
        So we use the second switch to ground signal somewhere in the Dirty preamp, silencing it.
        The "triangles" mean Gain Blocks in each Preamp, may mean one or more Tubes.
        *Personally* I would use 1 pair of EL34 which is the classic sound.
        Having a 50W output lets me reasonably clip it, for best/fattest sound, without killing everybody around.
        A too loud amp forces you to use buzzier preamp distortion all the time.
        Good luck.
        EDIT: *now* I see you will use a SE power amp.
        Forget my 50W suggestion (or not, why not go all the way and have a giggable amp?)
        My preference for EL34 still remains anyway.
