http://music-electronics-forum.com/t23653/
Earlier, I had posted the above question. Right after you guys gave me some advice, the noise issues went away completely for several days. Then, all of a sudden, they returned. So I started chop-sticking a bit more aggressively and found where the trouble is. Not sure what the SS Device is called. I guess it is the equivalent of power tubes. It is on page 3 of the schem (schem is in the above link) diagram on the right side. There are actually Two Times what the diagram shows.
Anyway....the trouble lies in one of those white, 15 pin (apprx 15) connectors. They are not 2 pieces, they are 1 piece. Looks like the wires are crimped into that white connector "block", then that whole thing is inserted into the PCB and then soldered. So you can not pull it apart. If I chop-stick that connector, I get all the noise I have been having problems with.
Sorry this is taking so long to explain....
What is the best way to deal with a bad/intermittent connection in one of these connectors.?
Thank You
photo link below
http://i111.photobucket.com/albums/n...moore/Haco.jpg
Thank You
photo link below
