I have 50 mV with or without the speaker connected using an 8 ohm speaker. Is this acceptable? The original owner replaced the stock 8 ohm speaker with a 4 ohm. Is 50 mV going to heat the voice coil??
Roland Cube 60 has 50 mV of DC offset.... What is considered too much?
Figure it out. 50mv through 8 ohms is 6ma of current. And that is 0.3 milliwatts.
You would have three tenths of one milliwatt of voice coil heating. A milliwatt being 1/1000th of a watt.
Rubbing your hands together and blowing on them would cause more heat.Education is what you're left with after you have forgotten what you have learned.
When it tells my amplifier-zen all-amp-oneness that it is a sign of trouble.
If I see a half a volt offset even under load, I am curious to know why it is there. SOlid state amps are so heavily fed back on themselves there really ought to be no offset. But a few millivolts are probably inevitable now and then. But that half a volt? If the amp sounds OK and shows no signs of trouble, I am not likely to know it is there in the first place. And certainly if it hits a volt or volts, then there is something wrong. Even a half volt won;t hurt the speaker, but to me it is an omen.Education is what you're left with after you have forgotten what you have learned.
