More gain - 5e3?
  • More gain - 5e3?
    Could someone here remind me how to jump the channels of a
    standard 5e3 together to produce more gain?
    Thanks in advance.
    PG59
    both inputs are at the same 2nd stage.
    look at any marshall diagram to cascade the stages
      I'm looking for directions like...normal x to bright z and plug guitar into y.
      Help...;
      PG
        Guitar into Inst #1, patch cord from Inst #2 to Mic #1.
          Tone 6 Inst vol 12 mic vol 6 .....Lp on bridge p/u, volume 10 tone 8
          equals Billy Gibbons Tush
          Watto
            My 5e3 has inputs - Normal and Bright.
            Of those two what are you guys calling inst. and Mic?
            Thanks for the help.
            PG59
            p.s.
            Watto - Thanks for any info about the Revs set up.
            You may have noticed that I am a big fan.
              Normal = Mic
              Bright = Inst
                Jumping the channels will not increase the gain. It will cause the two channels to be interactive, you can adjust both volume controls to tailure the tone to your liking, but the gain will not increase. I like to plug into the Bright channel #1 then run a patch cord from Bright #w2 to Normal #1.
                But there is also a lot of interactivity between the channels even when not jumpered. Try plugging into the Bright #1 channel and setting the Volume for that channel to about 6, then adjust the Volume control of the NOrmal channel and listen to the change in tone that results.
