Behringer pmh 3000 power supply failure
  • Behringer pmh 3000 power supply failure
    I have a pmh3000 and C26 in the power supply has blown. Does anyone know if or what associated components may also have to be replaced? There is an IC next to it 23849E IC6. The C26 failure seems to be random - it was not overheated, or very old.
    I used to know my way around power supplies, but not these modern switched mode types . . .Help!
    What is the power supply, an SPS600?
    Assuming so, a blown C26 implies suspect D24 that feeds it, and the TOP221 IC6 could have suffered.
