ac30 Clone Help
  • ac30 Clone Help
    Hello
    I recently built an ac30TB6 Clone using MM trannys, choke, webber chassis, sozo caps etc.
    The build went great, everything is neat and tighty. The power up went fantastic as well, no blow fuses and Voltages look great. It dose run very hot (16 watts dissipation) but from what I have read that is normal for the ac30 and tube life suffers.
    The amp sounds great and is quiet but there is not very much volume (all channels). All the way up sounds like it should be about half. I have a 5e3 that sounds louder.
    I have check and checked resistors pots etc.
    I am pulling my hair out.
    Does any one have any suggestions?
    I have tried multiple guitars, speakers, cables, and tubes.
    Any thought would be great I am at a dead end!
    This Thread should be relocated to the Amplification Forum!
    Good Luck,
