Results 1 to 9 of 9
Thread: Cornell Dubilier "greenie" capacitors
    Dec 2008
    774
    Received: 10/0
    Given: 1/0
    I've noticed that all of the CDE capacitors from the late 1960s in those light-green tubular plastic cases I've run across tested pretty much like new (very close to nominal value and low dissipation factor). I've replaced them, at times, for the sake of reliability, based on advice I've received, but I was still curious as to why they seemed to last so long with little observable degradation of performance compared to other capacitors from that time period (e.g., Sprague Black Beauties). Now I have a better idea.
    Not being able to find a CDE catalog from those years online, I e-mailed Cornell Dubilier, and, within a day, I got a response with a scan of a 1965 catalog. Unlike many popular capacitors from the 1960s, these have a Mylar film dielectric only; they're not a hybrid of paper and Mylar. The engineer who responded to my e-mail pointed out that these tend to last a long time for two reasons:
    The key to this series' longevity is the molded case (moisture resistant) and CDE's "Dykanol Y" impregnation (stopped using it because it contains PCBs).
    PCBs were good at controlling capacitor aging and stabilizing dissipation factor, but I wouldn't recommend cutting one open and ingesting the contents.
    Here's the scan for anyone interested. It also contains data on the "Budroc" capacitors you find in some vintage equipment.
    CDE Type PM.pdf
    Old Timer
    1,307
    Cool. So it appears the green ones are more likely to still be good. Thanks for sharing the datasheet! FWIW the CDE PKM ("Black Cat"--similar appearance but black cased) are AFAIK are polyester film + kraft paper, and some of the ones I've tested were usually a bit leaky (IIRC I also encountered a shorted .68uF).
    Jun 2006
    California, USA
    3,519
    Received: 95/0
    Given: 42/0
    Very interesting. I wonder if the blue molded caps used by Fender in the early to mid 1960's were made using the same process as the CDE greenies or were actually manufactured by CDE. The blue molded caps hold up very well. The yellow molded Astron caps used before the blues, on the other hand, virtually all went bad by the 1980s.
    Senior Member Mars Amp Repair's Avatar
    Sep 2006
    Englewood, CO
    812
    Received: 1/0
    Well,
    I obtained a whole bag of those green cornell dublier caps & have been using them very frugally in amps that 'deserve' them ;-]
    Old Timer km6xz's Avatar
    Dec 2010
    St Petersburg Russia
    1,841
    Received: 9/0
    The main reason tubular caps from that era went bad was leaks, more than stability of the electrolyte, although each had its some differences. The Black Beauties were made a little differently, they were filled through little brass tubes in the end of the cap that were sealed with solder or crimped after filling(over their production life Sprague tried a couple closure methods but with limited success). All those caps that had the little solder ball on the lead right next to the molded casing were filled that way and should be suspect. The same composition was used for some industrial and military caps that, if large values, could be refilled by design.
    I remember buying some new back in the late 50s and one had leaked in before I got it home. I never made anything using them after that. They were found in a lot of TV sets of the period and often there was an oily coating on the metal chassis from leaking caps.
    New Member
    Aug 2011
    1
    Quote Originally Posted by Mars Amp Repair View Post
    Well,
    I'm curious as to how the Greenies sound in your amps, and what portion of the circuit have you used them in? I've got a very few good Yellow Astrons (rare) and, like many, am trying to find something a cap relatively close to those in Tweeds. Thanks, Dale
    Dec 2008
    Wernersville, PA
    12,344
    Received: 99/0
    Given: 30/0
    So does this sound the death nell for Bumblebee caps.
    (as the market price collapses)
    Oh, it is so difficult being an audiofool.
    Sep 2006
    Englewood, CO
    812
    Received: 1/0
    Ya know, I had a tech who used them just because of all the mojo chatter on the web about them. Frankly, I'm not entirely convinced that any caps of quality in the proper application wouldn't provide the same sound quality as these vintage ones would. you could always buy those had wrapped 'Musicap' caps that CE Dist is offering for $$$$$ ea. glen.
    New Member
    Oct 2017
    North Carolina (USA)
    1
    Sorry to bring a thread back from the dead, but I am curious if the OP could provide the PDF again. When I click on it, I just get a single white pixel in the center of the display, lol.
    Thanks for the info you already provided on these vintage "Greenie" caps. I have also found these still test dead on to their rated value. I have checked them with a BK Precision 810C capacitance meter and an EXTech LCR Meter 380193, always within the 10% accuracy rating. I haven't had a chance to test them in an audio circuit yet.
  1. "Blows Fuses" and "Is my transformer dead?"
    By R.G. in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-14-2012, 03:03 AM
  2. irritating "sheen" on "A" notes
    By deci belle in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-12-2012, 01:34 AM
  3. Replies: 9
    Last Post: 02-24-2011, 04:21 AM
  4. "Difilm" paper/mylar capacitors
    By Rhodesplyr in forum Music Electronics
    Last Post: 02-15-2011, 10:03 PM
  5. Peavey Delta Blues - No Sound - All Tubes Glow - Powered "On", Made a "Hum", and died
    By Renegade44 in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-15-2009, 06:24 AM
