winding machine ideas/part suppliers
  • winding machine ideas/part suppliers
    Hello,
    Would really appreciate information on building a winding
    machine, and part suppliers. I have seen the sewing machine
    conversions and such, I was thinking I would like to at least like
    to build something more specific for the purpose. I have some
    motors,also enough machine tools to do light fabrication.
    I want to build different types of pickups, and try new ideas
    Thank you in advance for any help you can offer
    You know, basically any way to attach the motor to a speed control and make it spin a drive shaft will work. It doesn't really need to look or function a particular way as long as it performs some key functions: 1) motor spins a drive shaft which has a bobbin faceplate, or two, just depends on your design. 2) you need to have some method of counting turns. and finally, you need to make sure that you have some way to control the speed of the motor. You can basically use any method you like to get there. People have used everything from a mini-lathe to a retrofitted sewing machine, to a sewing machine motor in a box or a cordless drill even. There is a lot of information on here already. Use the search function to figure out what will suite your needs best. More specific question on here work a lot better for us.
      I can recommend 5/16 drill rod for shafting, then you can use skateboard ball bearings ($8 for 8 bearings!), then turn up a mounting plate for the coil holder. If you can find a DC motor, they are easy for speed control, just hook it up to a variable DC power supply. I found some pulleys and belts in an old bread machine.
      for a counter, I used the optical disc out of an inkjet printer that had an index pulse, ran that into a red lion counter. Worked great. Getting a good tensioner has been more difficult. One poster here suggested using the little polishing discs that come in a dremel tool kit tensioned with a strat pickuup mounting screw with the threads protected with heat shrink. That works, but I lose my tension setting every time I have to rethread the wire through the tensioner....Ah, problems...
      making 63 and 66 T-bird pickups at ThunderBucker Ranch
        Having your location posted under your user name others help you
        but if you live in the states you should be able to get everything you need besides the counter & sensor
        at McMaster-Carr
