bogen conversion
  • bogen conversion
    I just picked up two bogen p.a. amps a chb100,and an old e14.Any Ideas
    about converting to a guitar amp?
    Been done many times. One place to look for ideas might be Schematic Heaven. He has a section on PA conversions.
      If you can get past the looks, old PA's make great heads for cheap. Best of all, some are damn near bulletproof (or drummerproof). I did a Bogen Challenger?
      and an old Bell myself.
      Ken
      www.angeltone.com
        This one used to be a PA 50+ from sound city. Redid the faceplate with the original PA one erasing the unwanted text, and fitted the pots in the jack's holes, redid a basketweave tolexed front and back panel, since it went amis, and here ya go! I forgot, fake logo too.
          bogen conversion
          Thanks for the reply.The one I am working on is an e14.Bogen e-mailed me and said it is so old they dont have it in their archive.
          It has a pair of 6l6,2 6sf5,6f8,6c8,and5y4g rectifier.It looks simple enough to map out.I hav'nt been able to find schematics.There is one at info society that is close.First I cleaned it up,next I am going to change input/output jacks.Plug in a speaker and see what I get.Any comments are appreciated.
            Oh, I don't know.
            I think mine looks just fine.
            RCA 35 watt PA amp.
              Nice job!
                just one more tweak
                I think I have it where I want it.My wife says leave it alone and play it for a month. Rob mercure gave some helpful tips for the e14.
                I took the tone section out.Replaced the 50uf/50wv in the pre and middle with more fender type 22uf/1.5k res and 68 res athe input.This gave me a more workable sound.The "grid leak" type of bias made it sound a little to nasty for church,but it did handle a flanger/chorus pedal.The original sound was alot like the 50's gibsons
                I tried various cap and resistor combinations,what really helped was replacing the 50uf going from stage 1 to the middle stage.I traded some gain and volume,but its alot closer to a fender.
                Now I am temped to pull the whole 6sf5 pre out,put in cathode biased ax7's,or redo the whole thing.Although it is close to a 5d5.I better just play it for a month.
                  Which Challenger did you do? I won a ch-18 on Ebay, and cannot find a schematic anywhere. Got some Ideas where to look?
                  Bob
