I have some questions about a 1976 Twin Reverb that I am blackfacing but they apply to all Fender tube amps with reverb.
When troubleshooting by pulling tubes, in my case looking for a nasty hum, this is what I am seeing.
All tubes have been double-checked as "known good". With all tubes in place and volume at zero there is a hum. The hum increases with volume on both channels.
When I pull only V6 the hum stops at any volume setting.
When I pull only V1, V2, V3, or V5 the hum remains.
When I pull only V4, the hum is not present at zero volume or when I increase volume on the VIBRATO channel but the hum is present and increases when I turn up the volume on the NORMAL channel.
Does this mean the problem is in the output stage, possibly the changed values in the PI when I blackfaced it?
And because the hum was not present with V6 pulled, does this rule out the power transformer as the source of the hum.
This is my first posting and I deeply appreciate any advice.
