Results 1 to 3 of 3
Thread: The Pickup From HELL!
    ToneOholic! big_teee's Avatar
    Jun 2010
    Mid-South USA
    11,191
    Received: 752/32
    Given: 744/14
    21
    Every Winder that's been making Pickups for a while, should know what I'm talking about!
    You may wind several or many Pickups in a Row, without a Hitch.
    But, occasionly you will have what I refer to as the Pickup from Hell SynDrome.
    It may be wire want feed right and the wire will break. It may be that you get most or all the wire on the Bobbin to finally notice that the wire is wrapped around something. Or The wire gets under the bobbin, and you don't notice it until you get the whole bobbin wound and are taking the bobbin off the face plate!
    These things happen occasionally regardless of pickup type, single coil, Humbucker, bass, and guitar pickups.
    So this Thread is dedicated to all the Horror Stories of Winding, and please share your Pickup experience from HELL!
    The Humor of Winding.
    Later,
    Courage is being Scared to Death, but Saddling up anyway! (John Wayne)
    Oct 2009
    Beaverton, OR
    220
    Given: 3/0
    10
    I've had several as a result of a winder from HELL. I used the thread bobbin holder and sewing machine motor as the driven and driver and ended up with a 1 to 1 drive ratio. When you put the pedal down it was off to the races. If anything happened there was wire all over the place. Then, of course, it went so fast it shredded rubber bands and threw rubber particulate all over the place. Then the rubber band would break so I would have to stretch a new one over the spool and run it up and over the bobbin (try that one at 3:00am). Talk about scatter wound. It's amazing I ended up with anything that sounded good at all. But then again that could be one of those magical mojo things that I'll never get back when I finish my new improved winder. Ahh, noobness is bliss.
    Nov 2010
    DC
    145
    9
    It happens with guitars too. Sometimes you have a guitar that just EVERY step something goes wrong, or doens't work right, or you make a mistake. It's always SOMETHING. That's where this process comes in handy:
    Chris
  1. Replies: 9
    Last Post: 02-01-2011, 01:07 AM
  2. DB-01 Crybaby from Hell, Dimebag
    By theWicked in forum Guitar Effects
    Last Post: 01-19-2010, 05:20 PM
  3. PROBLEM: Crybaby From Hell WAH
    By spartadrive_in in forum Guitar Effects
    Last Post: 06-12-2009, 05:04 PM
  4. The hell with soldering
    By Alabam in forum Pickup Makers
    Last Post: 03-26-2009, 03:25 PM
  5. Rod Magnet Hell....
    By Stan H in forum Pickup Makers
    Last Post: 08-02-2008, 02:21 AM
