I have started here below three threads on a fu**ing Classic 30 that gave me a few headaches. This is a report of the repair jobs done.
1) smoke from the power tubes area: the CR6 diode on the plates of two power tubes got burned. I replaced it with two 1N4007 in series.
2) smoke from the preamp tubes area: R67 (180 ohm resistor feeding the reverb IC) got burned, due to a bad reverb IC. I replaced the resistor and trashed the IC (don't have a replacement at hand now).
3) loud crackles, pops and squeals, with blue light flashing inside the power tubes: I tossed the four EL84 and put a fresh quartet (JJ) in.
4) cold (dead) heaters in the preamp tubes: this was an error of mine - my bad! The filaments were on, but they have so faint a light that they really looked off! The tubes are three EH 12AX7. I thought that only Sovtek 12AX7LPS had apparently cold filaments. Actually these filaments here were alright.
Thanks to all the guys that helped me in troubleshooting! I have learned a lot along the way.
