stokes said in "The truth about filter caps" thread:
I have a problem in my Showman amp that I haven't been able to trace yet (still learning how to use a scope). There is a metallic overtone (that stokes describes) when I play the small guitar strings at various frets (A and C notes are the worst) especially when using the neck pickup w/ tone knob low for jazz.
When I changed the normal channel to a 5f6 (stole the vibrato tube) and added an extra gain stage with the extra triode— I added an additional filter cap/R for that normal channel mod. If stokes' comment is relevant to my problem, and it is also recommended to limit the number of stages per power node, I am at a loss what to do.
The metallic overtone is clearly audible in both channels. I have tried different guitars, cabs, speakers, cables, and preamp tubes. New filter/bias supply caps.
The only thing I haven't tried is different power tubes.
Any thoughts on Stokes' comment about not adding add'l filter caps to the preamp?
This sounds to me like filter cap issues.I have seen different noises that you may not think were caused by filters cured by using good quality caps.Another consideration when building or changing filter schemes,is not to use too big a cap for the preamp stages,or adding an additional cap in a circuit that uses one cap for two pre stages.I experimented with a 5E3 by adding an additional cap for the first stage and even with Sprague caps it was not good.
