Originally posted by Steve Conner
View Post
musicman rp-65 bias
KB
musicman 112 65 rd
Originally posted by Enzo View PostThe reason these are so cold it the amp is running pretty much in class B. They idle near cutoff. They idle at about 6ma.
The adjustment is 25mv across the 3.9 ohm emitter resistor. If they are not equal, set the lower one to 25mv as long as the higher one does not go over 55mv.
Note: use only 1458 op amp to drive this. Do not use 4558 or others.
