So I've rewired my JS1200 with updated satch pups, but I'm still getting the weird grounding hum problem. When I touch a pot I get a weird crackling sound unless I'm physically grounding the guitar using my finger (or pinch the bridge ground wire). Where is it going wrong?!
Dimarzio Wiring Problem
Hello Richard:
I notice no response.
I didn't see a ground to the 3Way switch housing.
Also I would experiment with the bypass cap on the vol.
I would take it loose to see if that changes anything.
Also I recently wired a customers guitar with 2 DPDT switches.
I used one for split, and the other one for Reverse Phase.
Worked slick.
You have 2 nice switches there but not utilizing them too much.
Make sure you have a real good ground between all the pots and switches.
Good Luck,
Rock On!
Terry"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Worked slick.
Good Luck,
Rock On!
Nope, nevermind
Oh well, I've ordered new pots and I"m gonna resolder the entire thing...
You sound pretty handy with a soldering iron, and test gear.
Did you take a ohm meter and read from the sleeve side of the jack to each component ground?
Also make sure the bridge ground reads low ohms.
Later,
* Edit Note:
Here's another wiring Diagram for a comparison.
It uses Seymour colors, you may have to sub your colors.
I've always had great luck with SD wiring diagrams.
http://www.seymourduncan.com/support...h_1v_1t_3w_2ppLast edited by big_teee; 04-25-2011, 04:58 PM."If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
