To all of youse who match your own mosfets for amps like the ampeg SVT and others. What kind of a set-up do you use and particularly in regards to current matching for the Ampeg SVT4? I was reading on the Pass DIY site about his setup, but it seems overly "flexible" for what I need to do -simple current measure. Also, would it be more meaningful to try and make a rig that simulates the actual circuit, ie. @+/-80volts on the drains and using a .47 ohm resistor on the source and a preset gate voltage (3.6v)?
Anyway what do you do to match output devices?
I recently scored a bucket of unused IRFP240/IRFP9240 mosfets and would like to sort them for use, esp in the SVT that I'm finishing up.
Matt
Matt
