Anyone know what this is? It's not stated inside or outside the cab and Eden had me on hold for too long.
Eden D210XLT cabinet - fuse value?
If I am not mistaken that is a 350 watt cabinet at 4 ohms.
An amplifier that puts out 350 watts at 4 ohms will produce a 37.4 Vac RMS signal.
Voltage / Resistance = Current.
37.4 / 4 = 9.35 amps.
That is the maximum current that the speakers will want to see.
An 8 amp fuse should fit the bill.
Go lower if you want to play it safe.
Thanks JPB... but correct me if I'm wrong - isn't the fuse typically only for the tweeter in such a cabinet? Is the tweeter really rated at that?? I'd guess that a tweeter does not need to be rated as high as a woofer since low frequencies tend to need more current... but maybe my assumption here is wrong. Finally, slo blo or fast?
Isn't it a tweeter protection circuit build using a light bulb? It is described in Eden manual: http://www.eden-electronics.com/info...abs_Manual.pdf page 6 (look for TWEETER LEVEL CONTROL). Such light bulbs are available from several internet stores; in Europe from Thomann.de. I don't remember the exact symbol.
EDIT: you may also read this: http://www.eden-electronics.com/info...weetertext.htm
or this: http://www.swrsound.com/support/manuals/html/bfoot.php
Mark
Anyway yall I just connected this fuse clip with a wire and the issue is still there anyway. I still need to know about the fuse, but apparently the absence of the fuse is not what is causing the symptom here. The symptom is that when the Eden WTX-500 (Class D) head is plugged into this cabinet there is a ticking sound. Each tick is about 1 second apart. This does not happen with another cab and does not happen with the cab and another head. ??
Originally posted by lowell View PostI just connected the speaker output of the amp to the woofer without the crossover. It works fine that way. Mark should I still try your suggestion without the protection circuitry? Or does this tell us something?
Mark
