Control Switcher + Pedal relays
  • Control Switcher + Pedal relays
    Hi there,
    I have a Voodoo labs control switcher with some spare switches on it and was wondering if its possible to modify a stompbox to be controlled by this? I assume that the control switcher is just 4 electronically controlled SPST switches. Could I just tap some wires off the switch built in to the stomp and run the to the switcher so that (with the stompbox switch in 'off' position) it could complete the circuit remotely? Or do I need to install a relay (and additional battery?) within the stomp? Is there a way to have a relay in there yet allow the pedal to function from its stock DPDT switch when used separately?
    A lot of questions there :S
    Many thanks,
    Eruera
