I was wondering how to properly rate the safety resistor, famously used in Ampegs. I currently have a 10W/220R from the 8R tap to ground, and measured 45 VAC across it with max signal, which comes out to 9.2W dissipation. Is this correct, or am I figuring it wrong because it's in parallel with the speaker?
Power rating for "safety resistor" across OT
You're correct with your calculation - which would exist if you didn't have a speaker connected, and maxed the pots with signal input.
However, average signal level is likely to be less, and hopefully you wouldn't play for too long before you realised there was no sound through your speakers! So resistor power rating seems fine.
Unless you have a 250W amp, then your protection resistor wouldn't see that max level during normal operation with a speaker.
There are other techniques that can also be added to help protect your amplifier output transformer than just a light load.
Ciao, Tim
The other technique I often use is a series MOV plus resistor across each primary half of a PP output transformer. The MOV has to be DC voltage rated (1mA level) at above the HT level. The resistor damps the MOV if it conducts, so I usually use a 2W rated at the nominal PP impedance (eg. 2k7 or similar). Smaller MOVs are preferred as they have almost negligible capacitance. Two MOVs can be used in series for a higher rating. Most of the movs used on 240VAC equipment have a DC rating pretty well aligned for 500-600V HT levels.
The aim is to catch any over-voltage swing on the cut-off winding side of the OT. The advantage of primary side protection is that is where the overvoltage occurs and where any consequential insulation breakdown occurs, rather than loading a reflected voltage on the secondary where the R loads at all signal levels.
Originally posted by Gaz View PostI was wondering how to properly rate the safety resistor, famously used in Ampegs. I currently have a 10W/220R from the 8R tap to ground, and measured 45 VAC across it with max signal, which comes out to 9.2W dissipation. Is this correct, or am I figuring it wrong because it's in parallel with the speaker?
-g
OK, so it is a big amp... One thought comes to my mind.. One could put the "safety resistor" across the 4 ohm tap... I would think it would still put the constant load on the secondary winding, but at almost 1/2 the voltage, but not quite 1/2 the voltage....
-g
Originally posted by Gaz View PostThanks, Tim. I've read about that approach in one of R.G.s "Immortal amp mods" articles, but he does not mention adding the series resistor. Interesting, and thanks again.
45vac RMS? With an 8 ohm speaker that is a solid 260 watts of power. That's some serious amp power there.
Is this the stock resistor that has been in there for ... years?
Because the two loads are in parallel, the total approximate impedance with the 8 ohm load is 7.72 ohms.
However, with respect to a real 8 ohm speaker, that depends on the frequency you are testing at too.
Most of the current is going into the speaker load since it is so low compared to the 220 R anyhow.
However... like you, I would be nervous with a 10 watter there and an open speaker wire connection.
I'd get one of those chassis mountable 25-50 watt aluminum Dale type resistors... with the small cooling fins.
