Results 1 to 5 of 5
Thread: Traynor YBA-3: voltages all look good, but low output
    Mar 2009
    450
    I've got a YBA-3 that's putting out really low power - 2VAC at the speaker. All voltages check out with the schematic, and a 1k sine wave test signal looks good at the grids of the power tubes, but is small and squashed at the output.
    My intuition tells me that it's gotta be between the phase inverter and the speaker jack. I tried new tubes, but got the same results. Could it be the OT? Or am I missing something. Thanks for any advice.
    P.S. for some reason the amp had a 12DW7 in the PI in stead of a 12AX7!
    Mar 2009
    450
    Awesome. Found the solution in an old thread where the (amazing) Enzo suggested the surge limiting components across the primaries. Funny, my inclination was right - that it was between the power tubes and the speaker - but I failed to notice (both in the amp and schematic) those two pesky components. Hopefully this can at least help someone else. And thanks Enzo!
    Dec 2008
    Wernersville, PA
    12,347
    Received: 102/0
    Given: 30/0
    Can you post a link to said Enzo post?
    Feb 2010
    10,189
    Received: 331/1
    Given: 652/0
    This one? http://music-electronics-forum.com/t14065/
    Seems to be fairly common fault in old Traynors that had them. Probably best to remove them if you come across them. Some folks may want to use the diode scheme instead. The factory never used to suggest replacing them with something else, just removal.
    Mar 2009
    450
    That's the one. Yeah, I just pulled the suckers out. Here's the schem (because there's a few different models) Prowess Amplifiers - Traynor - Schematics - Custom Special Yba 3 - Version 3
    This one's a bit better for bass than the one that's almost identical to a Plexi.
  1. Replies: 11
    Last Post: 07-04-2010, 02:50 PM
  2. question on traynor yba-1
    By Bruno in forum Vintage Amps
    Last Post: 05-29-2010, 04:38 PM
  3. Traynor YBA-1A...low distorted output.
    By acorkos in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-02-2009, 01:03 AM
  4. Vintage Traynor YBA-3 - First One Produced!?
    By vinylcollecter787 in forum Vintage Amps
    Last Post: 05-17-2007, 05:10 PM
  5. Traynor custom 40 low voltages
    By Guitarist in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-31-2007, 11:14 AM
