In high gain amps it's nice to supply the preamp with DC for the heaters. Helps keep down the noise.
The easiest way to get such a supply is to rectify the 6.3VAC supply and use one or more huge caps to jack the voltage back up. Back when I was doing the ol' ultra-fi we used to consider this a bit of a bodge, since that supply also went to the power tubes and the least hiccup would disrupt or destroy the supply. It also meant that the diodes would see serious instantaneous currents and the whole thing was a bit inefficient, unstable and unlovely.
Well, we have been seeing this same approach in mass market guitar amps for a few years. And we've been seeing problems from it. Gee, what a surprise.
I have now seen the absolute extension of this bad idea. Modern channel switching amp that takes a 6.3VAC supply feeds it to an 8A bridge then uses a 68,000uF cap to jack that up to 7VDC and then adds resistors and a trimmer to create a center point to produce a +/- 3.5VDC supply. This supply feeds the preamp tubes, Digital switching and relays. And surprise, surprise it is failing. The DC voltage was way low ~5V rail to rail, and got lower as the amp and bridge heat up. The preamp full of cold tubes is noisy, relays start to chatter, the amp fails to pass signal eventually.
Pull the preamp tubes and the voltage pulls up to spec. The bridge measures normal in circuit and it measures good out of circuit (passes DMM test and curve trace).
(How dodgy is this design? It uses paralleled wires and conx to get from the xformer to the PS PCB. Yeah, instead of using adequate wire and adequate connectors, they used more of them. Where the hell did these people come from that they consider that acceptable practice. It's one thing to double up for security entirely another to do it when one isn't enough.)
Call the manufacturer (not the name in big letters on the amp) and you get some hand waving about power tube heater to cathode leakage. Which may well be true in some instances, this circuit lives on a high wire so maybe that would be enough to kill it. Pulling power tubes had no effect on the unit on my bench.
What did fix the one on my bench was replacing the seemingly good rectifier bridge with one heavily derated. That was after replacing the fuse and securing/cleaning conx and reflowing everything.
What I don't get is that for a clean sheet design, why anyone would use this circuit. Back with the hifi amps we did it because we were modding and bodging and building for fun with existing components. Why the hell, when you've got to spec and order a transformer and design a power supply anyway wouldn't you start from the ground up.
If you need a DC supply, design a damn DC supply and be done and have a reliable, cool-running product. Bodging an AC supply when it isn't necessary doesn't even make sense from a cost POV. Not if warranty costs and reputation have any value.
If any manufacturers read this stuff consider it free advice from the field. Yeah, I know, I'm a tech and tech's always overbuild compared to engineers. There's a reason for that.
</Rant>
</Rant>
