Crate MX65R Amp Noise
  • Crate MX65R Amp Noise
    Hello All,
    Amp powers up fine, sounds fine when i run clean channel, or go direct into insert plug, bypassing everything and just using power amp. Problem is when i engage (star trek fans?) either of the two gain channels, (it has low dB and higher dB settings) i get a lot of noise out of the amp. signal comes through but has this loud buzz along with it. Anything past 1 on the level setting and it sounds like static ##@%*. Any suggestions about where to start? or what are likely the most common problems? Thanks for any help.
    I have a schematic on the way from Loud Technologies but its not here yet.
