Results 1 to 14 of 14
Thread: Can anyone ID this component please?
    Valvulados.com jmaf's Avatar
    Apr 2009
    Brasilia
    1,374
    Received: 42/1
    Given: 39/3
    12
    Hi, can anyone ID this component please?
    It's part of a preamp and seems to be somehow in shunt with a SPDT switch. Is it just a resistor with a cap as to avoid pops? I can't take the board apart and the trails are covered in black gook, I can't see what the connections are exactly...
    Thanks in advance for any pointers.
    Dec 2008
    807
    Received: 35/1
    Given: 11/0
    12
    It would help to have a little more information (what does the switch do?), but I have seen at least one three-terminal double capacitor used for power supply noise filtering. That one was a triple-layer disc capacitor with the center plate grounded.
    Apr 2009
    Brasilia
    1,374
    Received: 42/1
    Given: 39/3
    12
    Quote Originally Posted by Rhodesplyr View Post
    Thanks.
    The switch commutes between wires 1 and 3 right behind the component. Simple SPDT. I just assumed it's shunted to the switch, but I don't know really. I don't have this piece in hand and have no physical access to it to be able to test continuity from the exposed terminal to the base of the component, so this info is all I can provide. Thanks again for your suggestion, already searching 3 legged caps but found none similar on google and bing images.
    Any idea what that brand is? CM? MC?
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    11,753
    Received: 1,884/23
    Given: 1,463/35
    27
    I would also like to help, but
    is not the answer to rhodesplayer's question:
    What we need to know is *what* does that switch do?, meaning: does it switch DC/low voltage AC/110/220V/EQ/gain/channel? .... etc.
    Thanks.
    Apr 2009
    Brasilia
    1,374
    Received: 42/1
    Given: 39/3
    12
    I would also like to help, but is not the answer to rhodesplayer's question:
    Thanks.
    This circuit is on a bass guitar preamp. The switch commutes between active / passive outputs. I know I have little information to offer, I thought maybe by just looking at this thing folks would know what it is.
    Dec 2008
    Wernersville, PA
    12,997
    Received: 564/3
    Given: 298/0
    27
    It looks like an EMI filter.
    Why it is in that circuit, I do not know.
    Google Images: http://www.google.com/search?hl=en&x...og&sa=N&tab=wi
    Attached Files Attached Files
    Apr 2009
    Brasilia
    1,374
    Received: 42/1
    Given: 39/3
    12
    Quote Originally Posted by Jazz P Bass View Post
    Google Images: dss6nz82a103q55b - Google Search
    Nailed it, JPB, thanks very much.
    Oct 2007
    11,753
    Received: 1,884/23
    Given: 1,463/35
    27
    Interesting..
    Now that we know what it is, we can easily see the not-fully-dipped ferrite beads on the external legs.
    It's incredible how much hindsight we have *after* the fact !!
    I can only guess that the preamp maker must have had a *terrible* RF problem, specially considering it appears to be on the output.
    And I also guess that:
    explains the goop.
    Oh well.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    32,453
    Received: 2,009/7
    55
    Well, it is a commercial product, the amp maker didn't dip them himself. I see these all the time, especially around high gain inputs and anywhere where RF immunity is desired. Look for example it the input jack circuit of recent Marshall products like the AVT150.
    Apr 2009
    Brasilia
    1,374
    Received: 42/1
    Given: 39/3
    12
    I had never seen one, so good lesson for the day. Does it noticeably attenuate the high end? I guess for a bass guitar this will pass, but it probably loads guitar high end? Just curious, I was unable to tinker with it at all.
    Edit: I would assume 102 means a 1 nF capacitor for each leg, shared middle leg? If so, it'd definitely muffle guitar output...
    32,453
    Received: 2,009/7
    55
    We don't even know where it is in the circuit yet, do we? It mught roll off some highs if it were in series with the input signal, but it could also be in a control switching circuit and have nothing to do with the signal path. And consider that it is part of a whole circuit, so even if it rolls off some high end, in the overall picture that may be desirable. Most amps have a tone stack, and if you think about it, tone stacks roll off highs too.
    What preamp is it? Perhaps we can come up with the schematic for it and answer these questions.
  12. #12
    Oct 2007
    11,753
    Received: 1,884/23
    Given: 1,463/35
    27
    According to JazzP's datasheet, they are all "Pi" (don't have the symbol) type filters, series inductor/grounded capacitor/series inductor.
    The inductors are the part leads going through ferrite beads.
    The generic schematic shows a single capacitor to ground (through the center leg).
    Besides the effect on audio signals we can expect from a 102 (1000pF) capacitor to ground, they also post the attenuation curves at Radio Frequencies for the whole enchilada.
    They show dips at varying frequencies, I guess the designer chooses them according to expected interference trouble (FM?, TV?)
  13. #13
    Apr 2009
    Brasilia
    1,374
    Received: 42/1
    Given: 39/3
    12
    Thanks, Enzo. I don't recall the name. I'll make sure to ask next time I visit the luthier who was working on it.
  14. #14
    Apr 2009
    Brasilia
    1,374
    Received: 42/1
    Given: 39/3
    12
    Thanks for that. On the schematic there's also one without the inductors, and another with the inductors, I think they vary the kind of filter with the model(C, LC, whatever).
    It was good discovering what this component is and getting feedback from experienced members, appreciate that.
  1. Capacitor ID
    By trem in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-22-2011, 10:28 AM
  2. ID this part ?
    By Valvehead in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-21-2010, 05:37 AM
  3. Pickup ID?
    By ShannonH in forum Pickup Makers
    Last Post: 11-04-2009, 04:41 PM
  4. Help ID some speakers
    By Axtman in forum Vintage Amps
    Last Post: 07-23-2009, 05:52 AM
  5. need help - Old cap can ID
    By atmars in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-07-2008, 05:07 AM
