the amps volume seems to be going up and down by itself. could this be a bad rectifier? how do i diagnose this problem?
volume fluctuating
What kind of amp is it? If it has an effects loop then the loop jacks are the most likely suspect.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
To diagnose the problem:
I can't guarantee you have oscillation- But if it is then check the coupling capacitors. Good place to start. In the preamp stage if I go above 0.22uf output I get oscillation. You may have unintentionally installed a 0.22uf rather than a 0.022uf if you know what I mean.
Also, check the grid stop resistors. Does your amp have them? If so, maybe they are the wrong value. If not, try something like 15k to 68k. But first check your coupling caps.
Any luck?
If you switched out a tube(s) recently... go ahead and put a newer or older one in. I've personally had experience with a Groove Tube that caused oscillation. I simply switched out the tube and it stopped. However, the Groove Tube doesn't cause it in my other amps.
Still, not a lot of info to go by.
