5f4 build ?
  • 5f4 build ?
    Hey guys,
    I'm about to start a super tweed and the schematic I have calls for a selenium rectifier. Is there something I can use instead of this?
    chuck.
    Silicon: 1N4007
      Hi JHow,
      Thanks for the reply. How many 1N4007 diodes would I use in place of the selenium rectifier?
      Chuck.
        I see that ceritone uses one 1n4007 on their schematic,so is this ok?
        chuck.
          1N4007 is 1,000 PIV and 1A, so a single diode should be fine as the bias circuit is only around 50V, right? As you noted, ceriatone uses just one in this application. Anything more is probably overkill, but you can read here about diodes in series and snubbing with caps if interested:
          The Valve Wizard
