Deluxe Reverb clone - ugly distortion when v3 is connected - help!
  • Deluxe Reverb clone - ugly distortion when v3 is connected - help!
    I built this amp according to Weber schematic and layout.
    The amp sounds great, but when the volume is turned past 3 on the vibrato channel there is this horrible and VERY LOUD distortion, the ugly blocking distortion type.
    - Disconnecting the tank helps a bit.
    - With V3 out of the circuit, the noise goes away.
    - its not the tube, i swapped it
    Voltages on all the circuit seem to be fine.
    I have no clue about where is the problem.
    I have some experience dealing with blocking distortion, but i need to better isolate the problem .
    Would you help me, please?
    Felipe.
    I've seen this before on a silverface Vibrolux Reverb clone. The reverb drive (presumably V3 on your build) was being overdriven, and the distortion was being "splashed back" to the signal chain. I had to reduce the signal level into the reverb driver by adding a voltage divider in front of V3. Hope this helps.
    Joe.
