Hot Rod Deluxe III tone stack issue.
  • Hot Rod Deluxe III tone stack issue.
    Hey guys. I have a HR Deluxe III on the bench. Everything works normally except when treble pot is wide open. Then it sounds as if I am shorting the input with my finger. Customer says that V2 has been replaced due to failure caused by this issue. Any ideas?
    It does this even with the OD channel gain or clean channel vol turned down?
    What happens to the tone / waveform when it's doing this thing?
      Found the problem. Bad V1 12AX7. Thanks for trying to help, pdf64.
