Talking about David Becker's notes on modding the Peavey Classic 30 with the 'Tweed Basman Mod" on the Blue Guitar website.
So here I am stuck out in the backwater of the tube amp modding part of the planet that I am, and I can't get specified parts for the mod.
"Silver Mica caps" the shop assistant said - "never heard of them". So I managed to scrounge some polyester caps of nearly the same values (well actually a few 390pf a few more 360 pf and some other oddball values, which if I put in various combinations of series and parallel I can just about approximate 680pF in step 5 and not quite the 47pF in step 17). Comparatively minor frustrations.
Anyhow, I can't get a 25uF/25wvdc electrolytic (whatever that is) for the v2A cathode bypass cap substitute in step 8, so I presume a 22uF/25V electrolytic will give me damn near the same effect - feel free to correct me if I'm off base.
What's more, in Step 21, I can't get 1W 5k resistors anywhere in town so I presume 4.7k 1W resistors will be okay here (or should I go to 5.3K? - which is 'safer' - higher or lower?)
But the bit that's really got me stumped is step 12. Please see the attached .pdf. Can anyone tell me if I've got the arrow pointing to the correct trace in question? I understand this is fairly critical.
