Results 1 to 12 of 12
Thread: Boss PH-3 no effect
    Member Suburbanite's Avatar
    Nov 2007
    London
    84
    Boss PH-3 no effect
    Hi all
    Recently my ph-3 decided to up and die, it powers up (with battery and with power supply) but when you engage the effect..... nada, zilch, nothing. There is no sign of bad traces or components, the jacks all test out fine. I've had a look all over the interwebs, here and at boossarea and all I can find is problems with other effects.
    Whilst the effect is engaged if you turn the amp up pretty high you can just about hear a time based noise which makes me think this is not switching over to the effect path, similar to another problem someone had with a dd-3, but I cant work out which part to short out to turn the effect permanently on (to aid troubleshooting)
    also would love to get my hands on a schematic for it
    any help as always would be vastly appreciated
    Apr 2009
    Southern Connecticut
    150
    Schematic
    Here is a schematic.
    If you are able to get your hands on a scope and generator it should be a fairly easy repair.
    Boss PH-3 Phase Shifter Schematic.pdf
    Steve
    Nov 2007
    London
    84
    Thanks Steve,
    this should start me in the right direction, will have to wait a couple of days before I can borrow a scope (really need to get my own) so its just me and the multimeter for the mo and hopefully some luck
    3,722
    Received: 83/2
    Given: 9/0
    Not so sure that's gonna help since the Boss PH-3 is a very different beast from the Pearl PH-03 Phaser, which is the one you're showing (hint: the schematic you have is mislabelled).
    The Boss PH-3, a digital pedal, can be found if you do a Google image search for it.
    Jul 2007
    580
    Received: 16/0
    Given: 3/0
    Quote Originally Posted by Mark Hammer View Post
    Hi Suburbanite,
    If you have not even bypass, check
    1. Supplying voltages
    +9V on Q6 pin3;
    +8V on Q6 pin 2;
    +3.3V on IC7 pin3.
    2. If they are OK, connect generator to the input and check signal existence at the CODEC’s inputs (IC3 pins 3 and 5) and at the outputs (IC3 pins 24 and 26).
    Nov 2007
    London
    84
    Ha, that was my second ever pedal back when I was about 14, Found the schematic
    thanks anyway Steve - its the thought that counts
    Nov 2007
    London
    84
    Thanks Doctor, I pick up the scope on monday so will have a go then
    Dec 2008
    Wernersville, PA
    12,394
    Received: 143/2
    Given: 51/0
    Can you please post the schematic?
    Just so we are on the same page
    Nov 2007
    London
    84
    there you go
    Jul 2007
    580
    Received: 16/0
    Given: 3/0
    Quote Originally Posted by Suburbanite View Post
    there you go
    Hi Suburbanite,
    I think that now, when you have the schematic, you do no longer need my help.
    Good luck,
    Dec 2008
    Wernersville, PA
    12,394
    Received: 143/2
    Given: 51/0
    Darn shame it is so out of focus
  12. #12
    New Member
    Aug 2008
    2
    Hi Steve
    will you please send me the link for the Boss PH-3 Phase Shifter Schematic.pdf
    tks
    Neto
    netofer2@gmail.com
  1. BOSS CE-1 Stuck in EFFECT mode
    By looselectron in forum Guitar Effects
    Last Post: 11-03-2011, 01:34 PM
  2. Bogen PH 10 questions
    By wrathfuldeity in forum Conversion Projects
    Last Post: 07-26-2011, 04:35 AM
  3. Boss Ph-1R problem
    By Kangbee in forum Guitar Effects
    Last Post: 09-24-2010, 09:34 PM
  4. Replies: 3
    Last Post: 09-21-2010, 02:46 AM
  5. Broken BOSS Effect
    By martinez_90 in forum Guitar Effects
    Last Post: 06-29-2009, 08:27 PM
